- Thank you received: 2
Question IPB, Punbb, Phpbb3, SMF2 to Kunena solved
- forum-migrations
- Topic Author
- Junior Member
Migration State
Invalid query: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '00-'01','1231971498','93.103.59.70','0','0','0','0','78','0','null','null','null' at line 1 Whole query: insert into hms_fb_messages (id,parent,thread,catid,name,userid,email,subject,time,ip,topic_emoticon,locked,hold,ordering,hits,moved,modified_by,modified_time,modified_reason) values ('63','0','63','35','Anonymous','62','[email protected]','Akustika v ibiza '00-'01','1231971498','93.103.59.70','0','0','0','0','78','0','null','null','null');
That's an error on topics title, go to to PHPMYADMIN find the post with id 63, find the topic id, open the topic table and find with that id and check the title: look the solution that i posted (by a tester, i think that with large databases or sometimes the behaviour is unexpected) for modify test.php for fix a comma problem
About other question of menu elements, the script won't erase anything from the menu.
no problem.. as i write these lines, im doing a fresh install and let me see
i realy hope that won't be any trouble.
Every minute when im on Kuena ... im in love with it
- forum-migrations
- Topic Author
- Junior Member
I wrote you that try to find the topic title on the other forum, phpbb3 or smf or whatever, search for the character after Akustika v ibiza on the title (because something after that is causing the error), and if is the comma of the fixed line, change the line, if is other character try to modify test.php for replace it using the line as base for fix it.
I solved the problem just creating a new record for the super administratorAfter running the script I received a message on successful completion. The migration was successful, but CONTROL PANEL lost a few points as the site configuration templates. Do you have any ideas?
Can some one wrote simple FAQ to this migrator?!
I have installed phpbb3 in the url/forum/ and joomla 1.5.14 in root folder.
Name of joomladb is joom5 and name of phpbbdb is phpbb5.
I installed the Universal Password Integration - Forum Migrations
I uploaded the Migration folder to the Joomla folder and used the address url/migrator/index.php
What I must write in MYSQL User and MYSQL Pass forms? Or I need to import all data from phpbbdb to joomladb? Whatever I tried both ways and when I press Load Databases! I saw only "Fallo cargando la URL" Say please what I do wrong?
- forum-migrations
- Topic Author
- Junior Member
You need 1 mysql user with access to your phpbb database and Joomla database(is common on some servers use user cpanel data for mysql access).
Example: when installing joomla you have to write your database, mysql user and pass, use same user if have access to phpbb too.
Regards
I created a new folder in the root directory where joomla is and called it migrator.
I get an error, not the conversion. Any ideas?
SOLVED! I successfully converted over using the method posted in the kunena docs!!
I'm getting unresolved querry errors of "'re". Your script does effectively erase all users of the joomla database even if it errors out and doesn't import or migrate the users of the smf database.
I'm not versed enough with PhPAdmin or mysql to know how to resolve these queries without some instructions and I'm not going to chance another failed migration have have my existing users wiped out.
