Question IPB, Punbb, Phpbb3, SMF2 to Kunena solved
- rjbaker1178
- forum-migrations
- Topic Author
- Junior Member
- Thank you received: 2
Installed a fresh Joomla (1.5.15) and the latest Kunena.
Installed the plugin universalpassfm.php.zip.
Opened the folder migrator7 in my browser and followed the steps.
Message says it finished succesfully, but there are no categories in Kunena at all.
Even worse, my administrator login isn't recognized anymore, so I cannot access my Joomla backend.
Please tell me what went wrong.
- forum-migrations
- Topic Author
- Junior Member
About that error, you can try with this:
(by a tester, i think that with large databases or sometimes the behaviour is unexpected)
test.php
Change line 141 with this: (or find something similar)
if(gettype($val)=="string") { $final[$key]=html2bbcode(addslashes(html_entity_decode(str_replace('\'', '`', $val))));}
Because this test use a plain text mode
Thank you for your reply.
I've have tested and i like it.. but i have few errors :
Migration State
Invalid query: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '00-'01','1231971498','93.103.59.70','0','0','0','0','78','0','null','null','null' at line 1 Whole query: insert into hms_fb_messages (id,parent,thread,catid,name,userid,email,subject,time,ip,topic_emoticon,locked,hold,ordering,hits,moved,modified_by,modified_time,modified_reason) values ('63','0','63','35','Anonymous','62','[email protected]','Akustika v ibiza '00-'01','1231971498','93.103.59.70','0','0','0','0','78','0','null','null','null');
1.) then i checked on kuena forum.. Topic are showing but not the posts..
where i did go wrong..???
what i do
1.) i have silly webhoster so i've import database of phpbb forum tu my testjoomla database and then migrade.. ( why) because i use difrend usernames and passwords for my databases . this was the only way to even start migrate
can someone help me out ?
i really like more kuena then phpbb :woohoo:
one more error :
Migration State
Invalid query: Table 'antonioper_testphpbb.hms_fb_categories' doesn't exist Whole query: insert into hms_fb_categories (id,parent,name,cat_emoticon,locked,alert_admin,moderated,moderators,pub_access,pub_recurse,admin_access,admin_recurse,ordering,future2,published,checked_out,checked_out_time,review,hits,description,headerdesc,class_sfx,id_last_msg,numTopics,numPosts,time_last_msg) values ('20','116','LEON Mk1 LEON Mk2','0','0','0','0','null','0','0','0','0','20','0','1','0','0000-00-00 00:00:00','0','0','','','','5066','1','35','1246567261');
Some user asks also if it is valid for SMF 1.1.xx. Me too repete the request.
Please advice any metod to convert form SMF 1.1.xx to Kunena.
Thank you
The conversion script details are contained in the first message posted in this topic - see the link marked as "Release" - however, as forum-migrations stated that this only apply to SMF 2, knowing this information may not be entirely helpful to renzo unless he can adapt the procedure to his SMF 1 needs.
