Kunena 6.2.6 released
Important Avatar doesn't appear
The user's website, by default, uses PHP 4. This behaviour can be changed by adding the following lines to the .htaccess file:
We were running K 1.5.8 with customised site template, customised .htaccess file and non-standard Joomla file permissions. At this time, if you attempted to upload an avatar image you would receive no error message but, also, no image would be uploaded or displayed.
With the user's permission, I attempted to establish a stable base platform. I attempted to upgrade the site to J! 1.5.15 but I kept running into permissions obstacles. Then I ran into a PHP 4/5 conflict (fixed with the .htaccess file) when I attempted to reinstall K 1.5.9.
At long last, after establishing a stable base platform, I discovered that when you attempted to upload an avatar you would hit the problem described in Avatar upload problem >> JFile::copy: Cannot find or read file: for which there is a workaround.
The workaround is to change the following Kunena configuration setting:
Avatars » Avatar Settings » Image Processor = none
This is not a "normal" setting; this is not even a recommended setting but it is a solution to the problem. This seems to suggest that there is something defective in the background.
My thanks to morfina who has been very patient with me throughout this exercise - he's been up all night - not because he wants his problem solved but because he wants to help other users who might be in this situation. Therefore, he's the one who deserves a lot of the credit.
Can you please provide the URL and a test account to demonstrate the problem being discussed in this case?
I can, but the forum is in Hungarian, I'm not sure if you understood even a word.
Before I switched off the image processor option I hadn't even been able to upload any pics. With an error message I'd been refused.
I switched it off then the avatar uploads were successful, though they didn't show. :S
I even tried to replace the php file with the one you submitted, but it resulted in more php error messages. (Interestingly the content of that php file and the one comes with my installation archive is pretty different in a lot of rows!)
I feel desperate becaues it should work, but it doesn't. I have spent so many hours working on it and I don't know what to do.
You say you have checked "everything". For each of the dot-points listed in message #41205 , what are your responses?
Victorious wrote:
What were the PHP errors? What version of PHP are you running? There is only one difference (at line 335, there is one less { )I even tried to replace the php file with the one you submitted, but it resulted in more php error messages. (Interestingly the content of that php file and the one comes with my installation archive is pretty different in a lot of rows!)
I got no error messages but the imaged didn't appear to upload either
