Question Trying to install Kunena - having problems with directory permissions
13 years 9 months ago #21
by fxstein
Replied by fxstein on topic Re: Trying to install Kunena - having problems with directory permissions
Haveing experienced this now several times myself, I found one root cause for these permissions issues that we shoudl document on the wiki and also report back to the Joomla core team:
#1 issue I have seen for permissions issues are Joomla version upgrades
Yep, going from Joomla 1.5.15 to 1.5.18 based on the documented terminal option with
will reset the group and owner info on all updated files to invalid group and userids on mosty system. The reason being that tar will cary forward the group and user info from the source system where the tar was created.
On most hosting systems the owner and group should be apache:apache, therefore if you dont run
from the Joomla root, you will run into these permissions issues.
Also - you should never use nor have to use
Its an insecure work around to another problem.
tar -xvf upgradefile.tar
chown -R apache:apache *
chmod 777
13 years 9 months ago #22
Replied by sozzled on topic Re: Trying to install Kunena - having problems with directory permissions
Here's what we've said in the Wiki: Securing Kunena . Does anyone have some suggestions on how this advice can be improved?fxstein wrote: ... we should document on the wiki and also report back to the Joomla core team:
13 years 2 months ago - 13 years 2 months ago #23
by Maszek
Replied by Maszek on topic Re: Trying to install Kunena - having problems with directory permissions
Hi Sozzled,
On a different topic (upgrading to 1.6.3.), I granted write permission to all files and folders under com_kunena folder. The upgrade failed, but want to reset the permissions to default again. Regretfully the wiki you refer to does not reveal much. Is there a better source for this (securing Kunena)?
Can I help you guys out doing this for you? I'm not an expert, but I can list and summarize information based on sources provided.
Yours,
Jan
Yours,
Jan
Last edit: 13 years 2 months ago by Maszek.
13 years 2 months ago - 13 years 2 months ago #24
G'day, Maszek, and thank you. Any help that people can give to improve the quality of information in the Wiki is greatly appreciated. I agree that the current Wiki article
Security Kunena
lacks finesse (and I'm not sure how to improve on it) but it's a useful starting point.
Not all upgrade failures are due to incorrectly set folder/file permissions; there are also ownership issues involved, too. This topic originally started over a year ago and, at that time, the issues involved K 1.5. These days people are advised to use K 1.6 because the overall security of the product has improved considerably and, further, the original technical requirements article in the Wiki does not even mention file/folder permissions. Because our focus has shifted to K 1.6 we are no longer actively maintaining K 1.5 documentation.
The most important pre-requisites to ensure a smooth installation of Kunena are now contained in K 1.6 Technical Requirements and it's that article that people should look at first.
But if you think you can help, we would love to hear from you. If you have some further ideas about improving the file/folder permissions documentation, you can put them here under this topic.
Last edit: 13 years 2 months ago by sozzled.
13 years 2 months ago #25
by Maszek
I'll make some suggestions via PM
Time to create page: 0.519 seconds
