Question Trying to install Kunena - having problems with directory permissions
- RedElectro
-1 - An error has occurred.
It was not possible to copy the selected file.
Hence trying the tar version.
If it wasn't on a live site I would've tried manually deleting all the previous folders, but I didn't want to risk losing the forum completely.
Thanks...
Red.
That was it? That's' the only information you got? Was there more?-1 - An error has occurred.
- RedElectro
That's why I was puzzled as what to do. There's no specific error message, so no obvious course of action to take.
I'm sorry I can't offer any more information, but that's all I get myself.
I did get a couple of specific permission errors before this, so I altered the permissions until I'd done every relevant folder, then I got the white screen and message above.
1. The process doing the writing does not have write permission. In this case, we're talking about the Joomla installation process. If you can't install Kunena you probably can't install anything else, either.
2. The disk is full or you've used all your quota.
3. The disk is write protected or there is a disk hardware error.
In one of your earlier messages you referred to your tmp folder:
RedElectro wrote:
You said that you have changed the permissions on all "almost" every file and directory. When you changed the file and directory permissions, did you recurse those directories? What if you were to change the permissions on all directories, including the root?Uploading to Joomla, I got another error saying "Unable to write entry" and then this...
Warning: file_put_contents(/tmp/install_4b8c1cc774255/:K�]�]u��nZ���Ρ���J�����=��d�����w���$��?����K ݄�����hh�t��]d�4�~�cRO(妍) [function.file-put-contents]: failed to open stream: Is a directory in /****/*****/public_html/libraries/joomla/filesystem/file.php on line 298
If this does not work, would you be prepared for me to look at your system - I can't make any guarantees - to see what I can discover? I will require FTP access and super-administrator access to your administrator site. Please do not post those details here in the public forum.
- RedElectro
Are you saying to select all folders and set the perms to 777?
I can try that and if it doesn't work, I'll set you up an account and PM the log in details?
I don't know which specific folder you need to change. The easiest way is to change all folders. It's not a very scientific approach, but it might work. I'm still waiting to hear back from RedElectro on whether or not he was successful.I have the same issue, any advice to which folder the permission need to change to 777
This error comes from Joomla installer, so it's hard to know where the problem may be. Here are a few possibilities on kunena:
components
administrator/components
images
in your site this url: administrator/index.php?option=com_admin&task=sysinfo you have directory permissions: please take a look on it and fix the issues (red directories).
The problem is due to permissions. It is related to owner / group of who knows what files.
I solved it by running:
chown -R [Joomla website root]/* <owner>
chgrp -R [Joomla website root]/* <group>
and that cleared up the problem for me on my local machine (Mac OS X).
I previously did a chmod 777 * on the components and administrator/components folders, but that disn't resolve the problem, although the installer was able to create the com_kunena folders.
If you have shell access you can do this but be cautious. It may be that various files & folders have differing owners and group settings. The above 2 commands set EVERYTHING to the same owner and group.
