Question phpbb3 to kunena
xillibit reported all the steps, I just will add some carification:
-Before do a dump of your database
-Remove kunena and save tables jos_fb_*
-enable legacy plugin on Joomla 1.5, as this is required for fireboard 1.0.4
-Install fireboard 1.0.4. Create menu item for forums, go there to make sure it works. If no, go to admin part of fireboard and finish install.
-Download converter.zip, update go.php, copy to your server and then run it.
- Check forums. In my case I had to create new top forum and then assign all existing forums to that forum, otherwise there were issues.
-Run the com_fbconverter
-Install Kunena 1.5.6
- Install Kunena 1.5.7
- I had to move forums around again, otherwise forum would not show message. After moving formums everything looks OK.
Thank you very much for help!
There are no date set for the release of kunena 2.0, but there will be a version alpha soon.
and
Mark0100 wrote:
Hi Matias,
i would like to convert form phpbb2 (Orion2) over phpbb3 to kunena, but it is very very important and essential to migrate the attachments.
I need it very quickly, so can you make a script? I think K2.0 will take some time but I´d like to convert between christmas an New year.
is there something new??
it´s very urgent!!!
Gruß Mark
Pickup-Wohnkabinen-Forum Kunena 4.0.7
Chevy-Forum Kunena 3.0.8
look this thread for phpBB3 migration : www.kunena.com/forum/134-installation-up...t=10&start=100#40037
