Different error ==> Different solution ==> Whole other discussion.
There are
many useful tips contained in the
documentation Wiki
about installation timeout problems. I suggest you work your way through them. But there is no one solution to fit every possible problem scenario.
Although I doubt that you have manually changed the MySQL tables, your Joomla SQL database may be corrupted. Again, there's no one-size-fits-all solution for problems.
You may find other suggestions for getting the "Your Kunena installation is incomplete!" messages by searching the forum,.
In the meantime, to prevent the misuse of this discussion topic for problems relating to K 1.5.9, I am locking this topic in case others may be tempted to hijack it.
If you continue to have problems, and you are unable to find a solution, please start a new discussion topic relating to your specific problems. You may be assured that we will try to help you as best we can. Thank you ... and good luck.
