Question Convert SMF 1.1.10 to Kunena 1.5.6
Please, send a full stdout of script. May be it contain full SQL-instruction. It can help to find solution for you.Any idea?
- admiral_trigger_happy
No, you can't remove that.
I am willing to be it is finding a '' in smf_messages. Probably a ' that got changed into '' by the wonderful database demons.
I tried to do a conversion and got a similar problem
The export is putting '' (two separate inverted commas) where it finds a ' in the body text when I exported my tables too.
I'm did a find replace for '', to qqw, then I did a find replace '' to \' and I did a find replace for qqw, back to '',
(I'm pretty sure the '', is supposed to be like that thats why I changed them to something else then back)
Hopefully this will fix it, I'll report back
I done this, but he got another error - i also changed “ " ' '' and another, but got a break during converting...
any idea - or a new convert tool ?
Thanks alot JoseMaria
When I did it, I had to completely take out the '' . I didn not replace them with anything, not even with ' or \'.. I simply had to take em out completely. Have you tried doing that?
Also, what version SMF? My conversion was from SMF2rc1 and I had to do full table changes to make it work for example.
we got it thank you.
but we dont get the "statistic" of the old myBB - kunena begins to count the threads with zero (0) - do you know how or where i can import the old forum-statistics to kunena?
Thank you.
I don't know anything about myBB having only used it briefly as a test run back in the 1.2x days. THe only forum I've converted to Kunena is SMF2rc1. Perhaps using Kunena's Recount Statistics option will help here? I do know that the issue I had regarding is statistics is that it made all last replies and stuff before the converions to have taken place in 1969.
I have done a migration from MyBB 1.4 over SMF 1.1.10 successfull to 1.5.6 KUNENA...
Thanks alot i am happy now
- baijianpeng
- Premium Member
- Thank you received: 5
Which converter can do migration from SMF2 rc3 to Kunena 1.5.11?
Thanks.
www.joomlagate.com/
Chinese Joomla Users' Portal
