Question JS error when using BBcode
16 years 11 months ago #33320 by zilveer
Hi everyone,
I get JS error when I use BBcode on my page. For the moment I just use i locally so I have nothing to show up.
Anyway I used version 1.5.6 when I did a clean install.
It didn't work to use BBcode. I got the following error, I use firebug to get to know the problem:
syntax error
[Break on this error] color = String(numberList[r]) + Stri...rList[g]) + String(numberList<strong>);\n
Then I uninstalled it and used Kunena 1.5.7 but even though I get the same problem.
When I use any BBcode the BBcode doesn't show up in the textarea.
What could I do to fix this problem?
/Thanks for helping me..
16 years 11 months ago #33331 by Matias
We are using K1.5.7 in this forum and BBCode seems to work perfectly in here. Can you confirm that it works for you, too?
If BBCode works for you in this forum, there is most likely some kind of conflict between Kunena and some module or Joomla template you have installed.
If we find out what causes this error, it can be fixed. So first I would like you to switch using default templates in both Joomla and Kunena to see if that is the problem. If it does not help, try disabling modules to see, if it is some of them.
16 years 11 months ago #33345 by zilveer
hi..
i tried to use the default joomla theme but even though it doesnt work for me..
yes i can use bbcode in this kunena forum.. but i cannot get it work for me.
/bes regards
16 years 11 months ago #33361 by zilveer
hi matias,
i know what the problem is..
i did a pure clean installation of joomla standard without any templates.
then i installed kunena.. it worked like a charm..
in my other installation i have the rockettheme affinity template installed.. it seems to be conflicting with thair template.
how can we solve this?
16 years 11 months ago #33386 by Matias
I've been waiting for someone who could solve it with me, but I have never got enough information.
Already your first message reveals me something, so maybe we can get this solved this time!
It seems that the first conflict is "color".
Edit components/com_kunena/lib/kunena.bbcode.js.php and replace variable color with kcolor in lines: 86, 99, 100, 115, 116, 117. Do not touch anything else. Did it help at all?
16 years 11 months ago - 16 years 11 months ago #33395 by zilveer
hi,
i still get this error:
syntax error [Break on this error] kcolor = String(numberList[r]) + Str...rList[g]) + String(numberList<strong>);\n index.ph...2#content (line 425) colorPalette is not defined [Break on this error] &nbsp;<span style="white-space:nowrap;">\r\n index.ph...2#content (line 772) line 425 is: kcolor = String(numberList[r]) + String(numberList[g]) + String(numberList<strong>); line 772 is: colorPalette('h', '4%', '15px');
thanks for your help
Last edit: 16 years 11 months ago by zilveer.
