- Thank you received: 8
Question Direct (Auto) Quick Reply?
14 years 8 months ago - 14 years 8 months ago #12
Replied by sozzled on topic Re:Direct (Auto) Quick Reply?
I've been thinking about the value of this hack and I've decided that I was probably wrong with my initial reaction to the idea. Instead I have decided to incorporate the "always available" quick reply feature into a phpBB-like Kunena template.
Thanks, guerilla, for your contribution. I've made a small improvement (I think) to your idea ( #25999 )
Instead of changing
to
I've used instead:
This allows for the possibility that the forum is setup for public write access.
Instead of changing
if (!isset($msg_closed))
if ($kunena_my->id > 0 && !isset($msg_closed))
if (($kunena_my->id > 0 && !isset($msg_closed)) || $fbConfig->pubwrite)
Last edit: 14 years 8 months ago by sozzled.
13 years 9 months ago #13
by Clutch34
Replied by Clutch34 on topic Re: Direct Quick Reply?
So I wanted to try this on my Kunena website as well but I received this error message:
Parse error: syntax error, unexpected '?' in /home/xxxxxx/public_html/components/com_kunena/template/default_ex/view.php on line 1233
Line 1233 says this:
<table class = "fb_blocktable<?php echo $objCatInfo->class_sfx; ? >" id="fb_views" cellpadding = "0" cellspacing = "0" border = "0" width = "100%">
Any help on how to fix this?
Thanks!
Thanks!
13 years 9 months ago #14
by guerilla
Replied by guerilla on topic Re: Direct Quick Reply?
delete space between theese two character: ? >
it must be like this: ?>
- andreicukapp
13 years 2 months ago #15
by andreicukapp
Replied by andreicukapp on topic Re: Direct (Auto) Quick Reply?
how can I do this in kunena 1.6.1 or 1.6.2?
I cannot find those codes..
13 years 2 months ago - 13 years 2 months ago #16
by ChaosHead
Replied by ChaosHead on topic Re: Direct (Auto) Quick Reply?
Kunena 1.6.0 - 1.6.2
in file: view.php
after this line
(Such lines in a code two. After that that in the end.)
Add:
If want to remove all other fast reply buttons after each post: in a file message.actions.php delete a line:
Screenshot:
in file: view.php
after this line
<?php $this->displayThreadActions(1); ?>
Add:
<?php if ((CKunenaTools::isModerator ( $this->my->id, $this->catid ) || !$this->topicLocked)&&$this->my->id) :?>
<div id="kreply<?php echo intval($this->id)?>_form" class="kreply-form">
<form action="<?php echo CKunenaLink::GetPostURL(); ?>" method="post" name="postform" enctype="multipart/form-data">
<input type="hidden" name="parentid" value="<?php echo intval($this->id)?>" />
<input type="hidden" name="catid" value="<?php echo intval($this->catid)?>" />
<input type="hidden" name="action" value="post" />
<?php echo JHTML::_( 'form.token' )?>
<?php if ($this->allow_anonymous): ?>
<input type="text" name="authorname" size="35" class="kinputbox postinput" maxlength="35" value="<?php echo $this->escape($this->myname)?>" /><br />
<input type="checkbox" id="kanonymous<?php echo intval($this->id)?>" name="anonymous" value="1" class="kinputbox postinput" <?php if ($this->anonymous) echo 'checked="checked"'; ?> /> <label for="kanonymous<?php echo intval($this->id)?>"><?php echo JText::_('COM_KUNENA_POST_AS_ANONYMOUS_DESC')?></label><br />
<?php else: ?>
<input type="hidden" name="authorname" value="<?php echo $this->escape($this->myname)?>" />
<?php endif; ?>
<textarea class="inputbox" name="message" rows="6" cols="60"></textarea><br />
<input type="submit" class="kbutton kreply-submit" name="submit" value="<?php echo JText::_('COM_KUNENA_GEN_CONTINUE')?>" title="<?php echo (JText::_('COM_KUNENA_EDITOR_HELPLINE_SUBMIT'));?>" />
<small><?php echo JText::_('COM_KUNENA_QMESSAGE_NOTE')?></small>
</form>
</div>
<?php endif ?>
<?php echo $this->message_quickreply; ?>
Screenshot:
Last edit: 13 years 2 months ago by ChaosHead.
Time to create page: 0.516 seconds
