Question Community Builder login and register
- Gigameister
Disable the default login and put the module community builder in the position ja_login as this:
In configuration module_cb:
- Module orientation --> Horizontal
- Display tipe --> Compact
Put images for registration and lost password.
view example:
test...
Regards.
- Gigameister
i left it like you said, check it out...
Please test this in your site, uploading the attachament intro your_template/html/mod_login
Replace mod_login for this and test.
Regards.
Attachment mod_login.zip not found
- Gigameister
i only have an issue with having captch in the login, is it possible?
i use cb_captcha, it works in the registration page!
thank you so much for your help chema!!
If this matter does worry you then you should follow it up with the folks at Joomlapolis .
Calm, if the user is not registered can not access.Can be done, it's easy, but follow the link proposed for sozzled.
@Sozzled,
You are right.
Regards.
- Gigameister
thank you guys so much!
