- Thank you received: 97
Merged How to install a language when using Kunena 2.0.2
Kunena display your JOOMLA default language
TKtemp wrote: Hi,
So, despite having installed the language for Kunena; it has no effect, and you have to control Kunena's language using Joomla tools, where (in my case, with Spanish installed) I would have to install Spanish for Joomla and change default language.
I guess the Kunena specific words (haven't looked) will be in the Kunena spanish dictionary??
I can investigate this theory, but if you know the answer it will save some time.
It depends on how complete is the translation. According to the information here ( www.transifex.com/projects/p/Kunena/ ) it would seem that Spanish is 100% complete but, really, who knows?oldfart wrote: I guess the Kunena specific words (haven't looked) will be in the Kunena spanish dictionary?
1. Download the language pack from the downloads section
3. there is a directory called /languages, with a load of different languages for Kunena (as zip files) - select which one you want to install
4. Using JOOMLA's Extensions | Extension manager, Upload Package File;
upload the zip file you want to install. For this example I used Spanish:
5. You now have to install Spanish into JOOMLA: Extensions | Language Manager - click the Install Language Icon and search for spanish, select it and click the install icon.
6. Go back to Extensions | Language Manager - Spanish should be in the list - select it and make it default.
That's as far as I have got - this is what it looks like
Kunena language installer detect which languages are already installed on your Joomla site and install all present languages from package.
So, the right way to install kunena language (J!2.5) should be:
J!2.5
1. Install Spanish language for Joomla and make it default
2. Download language package from Kunena site
3. Install this package using Joomla Extension Manager
If installation fail:
4. Extract the files from the archive and install language file you wish using Joomla Extension Manager
J!1.5:
steps 1, 2 and 4 (step 3 doesn't work)
Best Regards
I am going to have a play with Joomfish - I know its only Beta at the moment for J!2.
Its going to take a while... but do you want me to report back how to do it?
Altough have tried ur advice, still don't work - As using installed lang. (Hebrew, in my case) as KUNENEA lang.
Again, Hebrew is installed & default on Joomla and also installed on Kunena - But still forum doesn't displays translation.
IT Consulting & SEO
articles depot | SEO | Israeli Film
