Solved Kunena Installation Failed! (Class 'KunenaRoute' not found in)
Here is the error I get when I install the latest version (4.0.6) of Kunena
Sorry, installation failed with following error:
Fatal error: Class 'KunenaRoute' not found in /homepages/6/d114815883/htdocs/giznaj_test/administrator/components/com_kunena/install/sql/install/php/sampledata.php on line 147
My Environment:
PHP Built On Linux info 3.0 #1337 SMP Tue Jan 01 00:00:00 CEST 2000 all GNU/Linux
Database Version 5.1.73-log
Database Collation utf8_general_ci
PHP Version 5.6.12
Web Server Apache
WebServer to PHP Interface cgi-fcgi
Joomla! Version Joomla! 3.4.4 Stable [ Ember ] 8-September-2015 21:30 GMT
Joomla! Platform Version Joomla Platform 13.1.0 Stable [ Curiosity ] 24-Apr-2013 00:00 GMT
User Agent Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36
PHP
PHP Version 5.6.12
System Linux info 3.0 #1337 SMP Tue Jan 01 00:00:00 CEST 2000 all GNU/Linux
Build Date Aug 24 2015 14:09:11
Thanks for the having the forum to log these issues.
Aaron
This error happens when the plugin system of Kunena isn't enabled or not installed, so try to install it in first (you can extract-it from Kunena package) and re-try to install the full package of Kunena
I installed the *package* contents in the following order.
- plg_system_kunena_v4.0.6
- plg_quickicon_kunena_v4.0.6
- lib_kunena_v4.0.6
- kunena_media_v4.0.6
- com_kunena_v4.0.6
All successfully with no errors. When I go to the component menu (Component -> Kunena -> Tools) in the admin control panel, I see the following error:
Prepare Installation ... OK
The folder path above doesn't exist in the file system after .../com_kunena as it's probably removed after the installation completes.
I'll continue to troubleshoot until I hear back.
Did-you have checked after the end of installation that the plg_system_kunena_v4.0.6 is right enabled ?tokenring wrote: Installed but not working.
- lib_kunena_v4.0.6
- com_kunena_v4.0.6
Installing Kunena - Alphauserpoints plug-in ... OK
Installing Kunena - Community plug-in ... OK
Installing Kunena - Comprofiler plug-in ... OK
Installing Kunena - Gravatar plug-in ... OK
Installing Kunena - Uddeim plug-in ... OK
Installing Kunena - Kunena plug-in ... OK
Installing Kunena - Joomla plug-in ... OK
Create kunena_aliases ... OK
Create kunena_announcement ... OK
Create kunena_attachments ... OK
Create kunena_categories ... OK
Create kunena_configuration ... OK
Create kunena_keywords ... OK
Create kunena_keywords_map ... OK
Create kunena_topics ... OK
Create kunena_messages ... OK
Create kunena_messages_text ... OK
Create kunena_polls ... OK
Create kunena_polls_options ... OK
Create kunena_polls_users ... OK
Create kunena_ranks ... OK
Create kunena_sessions ... OK
Create kunena_smileys ... OK
Create kunena_thankyou ... OK
Create kunena_user_categories ... OK
Create kunena_user_read ... OK
Create kunena_user_topics ... OK
Create kunena_users ... OK
Create kunena_users_banned ... OK
Install Sample Data ... OK
Recounting forum statistics ... OK
Installation completed successfully. ... OK
Looks it's all good on my side now. I guess Kunena will have an update in the near future to handle the installation error and error when going to the component when the system plugin is disabled.
Thanks again!
Aaron
Also, the post installation messages only displayed these rows as compared to before:
Database upgraded to version 4.0.6 ... OK
