- Thank you received: 1
Kunena 6.2.6 released
Solved Crypsis Template bugged?
- BamiGorengo
- Topic Author
- Junior Member
When i activate the Crypsis Template i get a error that tell me only:
500 Internal Server Error
Fatal Error was detected!
Please contact the site owner.
Any Idea?
Can-you enable debug mode into Joomla! and Kunena configuration panel ? Then you will see a more detailled error message instead error 500
- BamiGorengo
- Topic Author
- Junior Member
The error was detected in the Devmonkeys Template.
Fatal Error: Cannot redeclare class lessc_formatter_compressed in templates/devmonkeys/less/lessc.inc.php on line 3759
I develop a own kunena template and iclude there lessphp...
On my own template i get the same error...
I think its a problem with the Crypsis includet less compiler.
I have to find a way to fis this for MY tempalte to, any ideas?
Cripsys and "My Template" Works both fine when i use a default joomla template without includet lessphp.
I Mean this error happens only when i have includet lessphp in the SITE TEMPLATE "AND" in the Kunena Template.
Just add this on your index.php
Where 'yourtemplatename.less' is your main less file
- BamiGorengo
- Topic Author
- Junior Member
I tryed this:
and this to:
Nothing works
Edit:
With this i get error:
Fatal Error: Using $this when not in object context in components/com_kunena/template/dev_mafuba/template.php on line 14
- BamiGorengo
- Topic Author
- Junior Member
Tryed with your code but still same error: www.dev-monkeys.com/forum
Then you need just load the css.
- BamiGorengo
- Topic Author
- Junior Member
I see that you offer payed support?
maybe we can fix this problem together with skype and teamviewer?
i want to offer this template free and i think that this template will many people help.
thats why its verry important for me to make it running.
Put the complete file template.php here to see the issue
