Solved Kunena Installation Failed!
8 years 11 months ago #1
by Fox
- Demis Palma -
Kunena Installation Failed! was created by Fox
During an update from 3.0.4 to 3.0.7 the installation script stops with the following message
Installation Details
Preparing installation...
All subsequent attempts to load the kunena component in the backend, end with the same error.
The kunena frontend has been automatically set offline during the update, therefore our forum is offline until this problem will be solved.
The message shown doesn't help much. Failed... why? What exactly? What should I do?
Should I pray or what else?
- Demis Palma -
8 years 11 months ago #2
by 810
Replied by 810 on topic Kunena Installation Failed!
try to clean cache. And try again.
8 years 11 months ago #3
by Skyfox
Replied by Skyfox on topic Kunena Installation Failed!
I'm having this exact same error. Please see the attached screenshot.
No real information is given. I have tried clearing the cache and trying again, but no success.
Everything appears to have installed, the component is there. Upon going to the DASHBOARD option of the component, it appears to try to install again but fails with the same error.
Any ideas?
Any ideas?
8 years 11 months ago #4
by 810
try to disable all none joomla/kunena plugins, and install it again.
I think there is a broken plugin.
8 years 7 months ago #5
by AlexRag
Replied by AlexRag on topic Kunena Installation Failed!
I'm running into the same/similar situation and have tried the various tips on this forum, including disabling plugins. I can't even re-install the previous version of Kunena.
The site in question is running Joomla 2.5.28, along with the recommended flavours of PHP,etc.
I'm at a loss as to what to do.
8 years 7 months ago #6
by 810
try to check error log,
But it must be a plugin conflict. Or try clean cache before installing
8 years 7 months ago #7
by AlexRag
Good news. Your latest version 4.05 appears to have installed without issues. The one I tried before was 4.03.
Time to create page: 2.145 seconds
