Merged Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
Forum is down, please help!!
Should I reinstall an older version?
810 wrote: contact me by Skype: jelle810
Thanks for your help Jelle. You fixed it by disabling all non standard joomla plugins before installing, then after it was installed successfully you re-enabled them. Works now.
image:
im unistall and re-install is the same problem.
thanks.
Ok this work for install, thanks. :kiss:
I found an updated version of the "ECWID Single Sign-On Auth" plugin, and now I have no issues when I upgrade Kunena, so check your plugins from other developers to make sure they are up to date.
