Solved
Missing defines: are they present in the K 3.0.5 installation package?
hi, i've got kunena 3.05 installed over a v2 on joomla 3.3
i'm missing quite a few defines, can anyone tell me which file/location they would normally be in, in kunena
COM_KUNENA_THANKYOU
COM_KUNENA_VIEW_NO_TOPICS
COM_KUNENA_FORUM_HEADER
COM_KUNENA_POST_TOPIC_HISTORY
i assume its not that they're totally missing from the package, but if they are please let me know. i did copy the default blue eagle template to a new folder with some mods [and minor changes to code to match the new template name], it may be that i created the prob myself!.
btw i do upgrades through the joomla extension manager from the kunena file package on my pc.
It should not take a week to know if our advice has been helpful or not - especially if someone cannot install Kunena. We may have been able to give better advice if hareslade had submitted his (or her) configuration report; because we had no configuration report information to work with, we have to assume that our guesses were correct and that hareslade's problems have been fixed.
It does not take one week to install Kunena and to check that everything is working properly.
