Question Need hack to place ad inside 1st post, 5th, and/or last
- horseguards
- Topic Author
- Junior Member
I am moving from phpBB to Kunena, and in my previous forum I had a hack to show a 300x250 banner inside the first post, the 5th and/or the last post of a thread.
Like this awesomescreenshot.com/0f24atwm54
I don't want the ad under the post, I want it inside, like in the image.
Could anyone be so kind as to show me how to do it in Kunena?
Thanks!
replace this to:
and <p>test</p> to your wanted code
- horseguards
- Topic Author
- Junior Member
thanks a lot!!
I am sorry but I will abuse of your generosity: That is for one same ad. How can I do if I want to put a different add in each post?
Thank a lot, great help!!
And then create a banner module on the kunena_ads position. And set the banner to random.
- horseguards
- Topic Author
- Junior Member
This is what I get with either awesomescreenshot.com/0724cm9qf7
Any ideas?
- horseguards
- Topic Author
- Junior Member
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 247
Strict Standards: Non-static method JoomSEF::enabled() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 192
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 2752
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 427
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 450
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 202
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 366
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 373
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 381
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 281
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 286
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 287
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 288
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 289
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 290
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 291
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 292
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 595
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsefgoogle/joomsefgoogle.php on line 35
Warning: Cannot modify header information - headers already sent by (output started at /home/mcniac/public_html/plugins/system/joomsef/joomsef.php:247) in /home/mcniac/public_html/components/com_jfbconnect/libraries/provider/facebook.php on line 299
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/sef.router.php on line 301
Strict Standards: Non-static method JoomSEF::set() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.router.php on line 302
Strict Standards: Non-static method SEFTools::GetSEFGlobalMeta() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.router.php on line 302
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 48
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.router.php on line 305
Strict Standards: Non-static method JoomSEF::parse() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.router.php on line 310
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 837
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 837
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 891
Strict Standards: Non-static method JoomSEF::_parseAlias() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1013
Strict Standards: Only variables should be passed by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1013
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1550
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1551
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1551
Strict Standards: Non-static method JoomSEF::_parseSefUrl() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1031
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1060
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1062
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1063
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1063
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 35
Strict Standards: Non-static method SEFTools::getExtParams() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 36
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 169
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 169
Strict Standards: Non-static method SEFCache::getInstance() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 170
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 170
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.cache.php on line 250
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/sef.cache.php on line 250
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 183
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 296
Strict Standards: Non-static method JoomSEF::set() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.ext.php on line 307
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1230
Strict Standards: Non-static method JoomSEF::_sendHeader() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1374
Strict Standards: Non-static method JoomSEF::get() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1377
Strict Standards: Non-static method JoomSEF::_buildQueryStringValues() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1435
Strict Standards: Non-static method JoomSEF::_buildQueryStringValues() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1449
Strict Standards: Non-static method SEFTools::getExtParams() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1035
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/joomsef.php on line 1040
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.router.php on line 407
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/sef.router.php on line 407
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/components/com_sef/sef.router.php on line 386
Strict Standards: Only variables should be assigned by reference in /home/mcniac/public_html/components/com_sef/sef.router.php on line 386
Strict Standards: Non-static method JoomSEF::enabled() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 220
Strict Standards: Non-static method SEFConfig::getConfig() should not be called statically, assuming $this from incompatible context in /home/mcniac/public_html/plugins/system/joomsef/joomsef.php on line 225
This are just warnings, but they need to fix that to.
www.artio.net/support-forums/joomsef/pri...uge-amount-of-errors
- horseguards
- Topic Author
- Junior Member
I wonder if placing this type of invocation code, "Local Mode", could work. Could anyone tell me how to place this inside the post?
<?php
* Revive Adserver Local Mode Tag
* - Generated with Revive Adserver v3.1.0
define('MAX_PATH', '/home/ublicida/public_html');
if (@include_once(MAX_PATH . '/www/delivery/alocal.php')) {
if (!isset($phpAds_context)) {
$phpAds_context = array();
$phpAds_raw = view_local('', 48, 0, 0, '_blank', '', '0', $phpAds_context, '');
echo $phpAds_raw;
