Kunena 6.2.6 released
Solved SSL Mixed Content only in Forum
I am new to using SSL. I recently obtained a Security Certificate and implemented SSL. The whole site appears to be SSL compliant except the Forums.
I was wondering if anyone has any suggestions as to what the problem may be and how to fix it in the forum?
My forum is here: www.christforums.org
As you can see there's no mixed content anywhere else besides the forum? The only thing I could think of was the donation link, so I disabled that and still it had mixed content. I am shooting in the dark because I do not even know how to find the mixed content?
The mixed content error in Firefox Console Security says:
Blocked loading mixed active content " fonts.googleapis.com/css?family=roboto,H...eva,Arial,sans-serif "
Any help in fixing this would be much appreciated!
so you need to check your joomla template. and change it to https://
Thanks 810
Open your index.php and search for:
change it to:
I do see the line you are referring me to though when I view the "source" of my forum.
I do not believe the issue is with the Joomla template, but the 3rd party template I'm using for Kunena. When I test with the default blue eagle, there is no mixed content, it's strictly ssl.
I have no idea how to find the file where the http:// address exists in my Roundtheme template for Kunena.
I put in a support ticket for Roundtheme, and will await there response if there is no solution elsewhere.
Thanks!
