Kunena 6.2.6 released
Question "The forum is currently offline for maintenance"
9 years 7 months ago - 9 years 7 months ago #1 by LTCreations
My installation "was" working fine. I did move a few months back. Because of some changes I know there was no activity in the forum, and I was busy with other projects. But today I changed to remove Akeeba Subscriptions as the "front" for Kunena, and changed the menu item to one that goes directly to Kunena.
I checked the configuration, assured that the menu item is published, along with many other settings that may cause the problem.
But I keep getting The Forum is currently offline for maintenance.
It's not.
I've checked 3 times.
I even reinstalled the 3.0 version, then the 3.0.6 - all to no avail.
Here is the report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : ltcreations2012 | author: | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: Search - Kunena Search 3.0.0 | Content - Kunena Discuss 3.0.0 | JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Latest 3.0.0 | Kunena Stats 3.0.0 | Kunena Login 3.0.0 | Kunena Search 3.0.0
I'll dig into the database if necessary, but I wanted to check here first. I found several posts about the same or similar issue. Although I've not found a resolve other than the German post that, in brief, stated to disable everything but Kunena, hit the menu item to the forum, get it to work, then enable everything again.
That really doesn't sound like a good solution if it's going to "mandate" that I perform those actions.
It seems to me there must be something much more simple.
It gets deeper.
I found that the db had some overhead and I repaired rather than optimized. No changes.
I now have an error (after assigning the Kunena login module to a couple of pages) that states - ERROR: mod_kunenalogin: Kunena 3.0 (or later) is not installed on your system
What's going on?
Kunena has been around forever and worked flawlessly.
In my search for the error, there are over 2,500 sites that have the exact same error.
YouTube.com/@SEO-Tom
Last edit: 9 years 7 months ago by LTCreations.
9 years 7 months ago #2 by Mortti
Maybe this has something to do with it? --> screencast.com/t/7MJ7Zrhs8O
9 years 7 months ago - 9 years 7 months ago #3 by sozzled
There are also a couple of other things you can do.
1) Change your forum integration plugin settings as shown in red text below:
Kunena - JomSocial Enabled: Disabled
Kunena - UddeIM Enabled: Disabled
2) Uninistall the following Kunena add-ons :
  • Search - Kunena Search 3.0.0
  • Content - Kunena Discuss 3.0.0
  • JomSocial - My Kunena Forum Menu 2.0.4
  • JomSocial - My Kunena Forum Posts 2.0.4
  • JomSocial - Kunena Groups 2.0.4
  • Kunena Latest 3.0.0
  • Kunena Stats 3.0.0
  • Kunena Login 3.0.0
  • Kunena Search 3.0.0
Last edit: 9 years 7 months ago by sozzled.
9 years 7 months ago - 9 years 7 months ago #4 by LTCreations
Thanks for the replies.
I was well aware that I'd turned off Akeeba Subscriptions, but it wasn't working prior to that. I don't know if it had anything to do with Kunena or not.
I followed your removal instructions, but that didn't make any difference.
Specifically, some of the 3.0 items weren't there, but I removed what matched.
Now what?
Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 64M
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1
Last edit: 9 years 7 months ago by LTCreations. Reason: Add Report Configuration
9 years 7 months ago - 9 years 7 months ago #5 by LTCreations
In an effort to further test, I attempted to install Kunena 3.0.6 in a completely different site using Joomla 3.3.3
I attempted the install from the new Joomla (3.3.3) Install from Web and got the following error:
Sorry, installation failed on fatal error!
So, I thought I'd install from the downloaded file (pkg_kunena_v3.0.6-2014-07-28.zip).
I got an immediate response on the primary upload that said the package uploaded successfully.
Message
Installing Kunena...
Installing package was successful.
But the secondary portion of the installation, where the "pop-up" window shows the progress bar, there is less than 5% progress and the same error appears:
Installation Details
Prepare Installation ...OK
Installing Kunena - Alphauserpoints plug-in ... OK
Installing Kunena - Community plug-in ... OK
Installing Kunena - Comprofiler plug-in ... OK
Installing Kunena - Gravatar plug-in ... OK
Installing Kunena - Uddeim plug-in ... OK
Installing Kunena - Kunena plug-in ... OK
Installing Kunena - Joomla plug-in ... OK
It seems something inherently wrong with 3.0.6
I'm sure many people don't have any problem. But "something" in the package is not right, apparently.
I've also found this in where the Kunena menu if supposed to appear:
ERROR: mod_kunenalogin: Kunena 3.0 (or later) is not installed on your system!
If that were true I wouldn't be able to post the report above.
9 years 7 months ago #6 by Wilson
Time to create page: 0.481 seconds
