configuration report
Important first 5 posts of a new page cannot be read
9 years 6 months ago - 9 years 6 months ago #1
by Careggi
first 5 posts of a new page cannot be read was created by Careggi
I am a newbie and I'd like to ask a generic question.
The forum I frequent works quite well most of the time but I noticed that once a topic grows in size, the page numbering routine fails.
Each page has 10 posts. Once you write the 11th post, it becomes the first post of the next page. Well this is how it should work.
Unfortunately on many topics which have several pages (say >100) the 11th post does not appear on the new page until the 12th is written. As the topic gets bigger the posts that do not show increase to 2, 3 , 4, 5, ecc.
I can give you the link to one of the topics that has this problem.
www.futurimedici.com/index.php?option=co...60&Itemid=343#311887
On this forum I generate a lot of tables and statistics like the following one and I think that these may "upset" the page numbering routine
Careggi V3 10 SET (N°13) 11887 11MP40135 bea_drago94 32.7 Prenotato O.Firen/Siena
1_____2____3___4____5____6_____7_____IND___IND____________
Pos___Pos__Pos_Pos__Cand_Cand__TOT___10 SE_POS_ATENEO_____
Tot___IMM__Ass_Prn__Crti_Virt__________________<=11886____
274___221__1___52___31___421___452___9_____0.6_M.Genova___
166___166__0___0____31___668___699___XXX___XXX_M.Pavia____
141___141__0___0____48___655___703___XXX___XXX_M.Bicocca__
373___373__0___0____141__666___807___XXX___XXX_M.Milano___
390___378__3___9____89___495___584___XXX___XXX_M.Torino1__
123___112__0___11___16___392___408___XXX___XXX_M.Torino2__
261___209__14__38___24___580___604___12____0.6_M.Parma____
238___237__1___0____93___530___623___XXX___XXX_M.Pisa_____
100___94___0___6____29___333___362___XXX___XXX_M.Avogadr__
346___311__6___29___82___667___749___XXX___XXX_M.Firenze__
234___167__0___67___21___455___476___7_____0.3_M.Siena____
419___419__0___0____83___771___854___XXX___XXX_M.Bologna__
127___127__0___0____29___533___562___XXX___XXX_M.Modena___
219___210__5___4____28___620___648___XXX___XXX_M.Ferrara__
225___223__2___0____59___512___571___XXX___XXX_M.Brescia__
160___155__0___5____37___405___442___XXX___XXX_M.VaInsub__
180___180__0___0____65___587___652___XXX___XXX_M.Verona___
430___430__0___0____138__637___775___XXX___XXX_M.Padova___
145___137__8___0____24___411___435___XXX___XXX_M.Trieste__
108___108__0___0____38___361___399___XXX___XXX_M.Udine____
165___134__0___31___25___443___468___15____0.8_M.S.Andea__
123___52___0___71___5____386___391___6_____0.1_M.PontSap__
592___568__1___23___114__505___619___XXX___XXX_M.PoliSap__
226___225__0___1____55___471___526___XXX___XXX_M.TorVerg__
237___197__0___40___18___329___347___9_____0.5_M.Perugia__
159___153__2___4____34___237___271___XXX___XXX_M.PolMarc__
221___175__0___46___13___223___236___5_____0.3_M.Chieti___
80____47___0___33___0____139___139___4.2___0.0_M.Molise___
160___123__0___37___10___193___203___5_____0.3_M.L'Aquil__
415___413__1___1____80___220___300___XXX___XXX_M.NapFed2__
440___340__1___99___22___121___143___1.4___0.2_M.NaSeUni__
80____68___0___12___13___148___161___XXX___XXX_M.Foggia___
239___236__3___0____71___141___212___XXX___XXX_M.Bari_____
200___180__1___19___10___117___127___6_____0.5_M.Salerno__
264___150__0___114__1____9_____10____0.1___0.0_M.Catanzr__
405___376__0___29___25___73____98____3.4___0.9_M.Palermo__
320___319__0___1____68___93____161___XXX___XXX_M.Catania__
225___137__0___88___1____36____37____0.4___0.0_M.Messina__
205___194__1___10___25___70____95____XXX___XXX_M.Cagliar__
133___90___0___43___2____49____51____1.2___0.0_M.Sassari__
25____19___0___6____0____1_____1_____0.2___0.0_O.Genova___
18____16___0___2____0____8_____8_____4.0___0.0_O.Pavia____
27____25___0___2____0____11____11____6_____0.0_O.Bicocca__
60____51___0___9____0____8_____8_____0.9___0.0_O.Milano___
45____43___0___2____0____6_____6_____3.0___0.0_O.Torino___
23____15___0___8____0____1_____1_____0.1___0.0_O.Parma____
15____12___0___3____0____14____14____4.7___0.0_O.Pisa_____
56____29___0___27___0____0_____0_____0.0___0.0_O.FiSiena__
Can anyone help me understand how to fix the problem please ?
Thanks in anticipation..Careggi
Last edit: 9 years 6 months ago by Careggi.
9 years 6 months ago #2
by rich
Replied by rich on topic first 5 posts of a new page cannot be read
There are also deleted posts in this topic? Then this can happen. Go in backend to "Kunena > Forum-Tools > Recount Statistics" and let count all statistics. That should help you.
The following user(s) said Thank You: Careggi
9 years 6 months ago - 9 years 6 months ago #3
by Careggi
Replied by Careggi on topic first 5 posts of a new page cannot be read
Thank you for your response Rich.
No, there are no deleted posts, only modified ones.
This problem has been more frequent recently as the number of tables published has increased. However I haven't been able to pinpoint a specific event.
The only solution that gets around the problem is to start a new topic. A new topic will not show the "page numbering illness" until many pages have been published.
This is a typical content of the tables which may help you with the diagnosis
Once again, thanks for any help that you can provide.
PS The topic which I referenced earlier is at page 887 (10 posts per page) and the first 5 posts on page 888 will not be viewable until a user posts the 6th for that page.
[color=#0000ff][font=courier][b]Careggi V3 10 SET (N°13) [b][color=#ff0000]11887 11MP40135 [/color][/b]bea_drago94 32.7 Prenotato O.Firen/Siena[/b][/font][/color]
[color=#0000ff][font=courier][b]1_____2____3___4____5____6_____7_____IND___IND____________[/b][/font][/color]
[color=#0000ff][font=courier][b]Pos___Pos__Pos_Pos__Cand_Cand__TOT___10 SE_POS_ATENEO_____[/b][/font][/color]
[color=#0000ff][font=courier][b]Tot___IMM__Ass_Prn__Crti_Virt__________________<=11886____[/b][/font][/color]
[font=courier]274___221__1___[b][color=#ff0000]52[/color][/b]___31___421___452___[b][color=#ff0000][/color][/b]9_____0.6_M.Genova___[/font]
[font=courier]166___166__0___[b][color=#ff0000]0[/color][/b]____31___668___699___[b][color=#ff0000][/color][/b]XXX___XXX_M.Pavia____[/font]
[font=courier]141___141__0___[b][color=#ff0000]0[/color][/b]____48___655___703___[b][color=#ff0000][/color][/b]XXX___XXX_M.Bicocca__[/font]
Time to create page: 0.369 seconds
