Kunena 6.2.6 released
configuration report
Question Changing the boardcode options
9 years 8 months ago - 9 years 8 months ago #1
by remco123
Changing the boardcode options was created by remco123
How do I change the boardcode options? I don't want my users to be able to place any html code and even all the other options in the menubar. Only the smileys should be allowed.
(As an alternative users may post HTML code after a certain number of postings.)
I also want to hide the "Topic Icon" bar or at least configure which icons are shown.
Can you please show me how to fix this?
gr,
Remco
gr,
Remco
Last edit: 9 years 8 months ago by remco123. Reason: error
9 years 8 months ago #2
by Matias
Replied by Matias on topic Changing the boardcode options
In Kunena you cannot currently easily disable BBCode, but you can hide the buttons by changing your template.
Topic icon selection is by default only visible to topic starter and moderators. There's also automatic mode which is configured from Frontend > Selectable Topic Icons
9 years 8 months ago - 9 years 8 months ago #3
by remco123
Replied by remco123 on topic Changing the boardcode options
ok the topic icon thing is fixed but about the boardcode options you say:
"you cannot currently easily disable BBCode"
not easily but doable I presume? So it is possible by hacking the .php file
And the other option "but you can hide the buttons by changing your template".
How is that done? In my template manager I use blue eagle and when I choose Edit, under Button Set I can only choose from default/bluebird/graybird/blackbird/whitebird.
Plz let me know.
gr,
Remco
Plz let me know.
gr,
Remco
9 years 8 months ago #4
by Matias
Well, there is.
You can add and hide buttons from here:
github.com/Kunena/Kunena-Forum/blob/mast...na/bbcode/editor.xml
But that will not disable BBCode from a user who knows how to use it. If you want to disable BBCodes themselves, you should remove them from here:
github.com/Kunena/Kunena-Forum/blob/mast...na/bbcode/bbcode.php (line 265+)
Of course those are just hacks in the library and they need to be reapplied every time you upgrade Kunena.
9 years 8 months ago #5
by remco123
Ok thanks, I will try to figure this out.
But maybe for a new version you can build in the function that you can disable those buttons from the backend, just like the ebay buttons etc.
That would be keep some spamming out.
Time to create page: 0.363 seconds
