Kunena 6.2.6 released
Question Custom Kunena Menus for different categories?
rich wrote:
Yes, that's correct. You need menu button for each section. You can hide the tabs via css afterwards. That's the easiest way.However it seems i must have the menu button for each section or it will lose the override and display the default site template (no override).
This seems to be very cumbersome way of doing this. Is there no better way?
Also what about this question?
Will they ever make it so that we can use the New menu option "Home" to have different versions, this to me seems like it is already built in as the home menu button allows the selection of specif categories and or sections. If i could simply make new Home pages say home, home2, home3 and so on it would be the easiest way to do this. I have tried to make a home2 but it simply does not work and always defaults to the home, is there some way to use this and get it working? Or is this something planned for future versions?
I'm sorry, but this is the easiest way. You want a very comprehensive Forum. This will require some time and Work.This seems to be very cumbersome way of doing this. Is there no better way?
OK, your forums do everything we want, and the thing is it seems like this functionality is already built into it. Please consider adding this feature in the near future. Or a link to submit requests for new features.
Can you please provide information on how to hide the menu items with CCS as i am not sure how to do this.
Regards
If you want only single tabs are hidden, then use Firebug and search the items from the tabs.
www.kunena.org/docs/Firebug
for example: your new tab has item987
Then add at the end of your Joomla! template.css the code
Copy Kunena Menu into two other locations Game1 and Game2. After that just go to 'Forum' menu item of both Game1 and Game2 and click on 'Main settings' tab. In there you can see 'Allowed Categories', where you list only those categories which belong to the current game. After this you just need to assign the same stuff (modules, template) for all Kunena sub menu item.
If you do the same for Kunena Menu as well, you have forced Kunena to stay in the current menu structure.
Matias wrote: How I've done this in the past is that you start from a site that has only Kunena Menu.
But what if the site is already live and has a main menu in it, is there no way to do this without deleting all other menu items?
Thanks for your support, i knew there had to be a way in the existing code as it seemed to me like it was already there.
Best Regards
Alan
I think I'm going to look deeper into this issue and try to figure out how to solve it in a real multi-forum support for Kunena 3.1...
Right now the support is somewhat limited and sometimes also hard to do it in a right way. For individual categories without a Kunena menu on top of it, you can just create category menu item and at the same time remove the item from the main Forum menuitem. If you want to keep the menu, you need to copy the whole menu to the new location and assign wanted sub-categories to the new item as well as removing them from the main menu.. And so on.
Matias wrote: I think I'm going to look deeper into this issue and try to figure out how to solve it in a real multi-forum support for Kunena 3.1...
Thanks for the info, I would love to see a true Multi-forums support in Kunena. Will you update this posting when you have added this into the new Kunena 3.1? so we can help test it for you once its ready?
Kind Regards
Alan
