- Thank you received: 566
Question User subscriptions and forum performance
I've not run anything like this before and I believe that the reason why it's been open for so long as unresolved is that nobody has a glue on how to fix the issue.
I believe that the only way to solve this issue is to add some timer points to the code and look at what is what is taking all that time. For basic profiling you can enable KUNENA_PROFILER define inside administrator/components/com_kunena/api.php line 16 and to prevent posting from redirecting the page in components/com_kunena/controllers/topic.php around lines 215-221 and comment out the redirects. But I doupt that it helps much without adding some timer points into the code.
Although I know how to edit code, I really don't know to add the things you mentioned. Yes it is frustrating, but thanks anyway.
If you give me super administrator access and permission to mess up your site (I would prefer if you made a copy of it in the same server), I can try if I can track this down with a few custom builds. I'm not promising anything, but in this way there's a change to learn where this major slowdown might occure.
Matias wrote: I think that your issue is something that's worth to investigate as I think we've had few other reports with similar slow page loads which only happen during the posting. This kind of issues are so rare that we have not been able to track the issues down -- in fact I do not know when was the last time I've seen this kind of issue. It has to be months or even a year ago.
I can give you access to duplicate the site. I assume you need FTP access?
You can put the login information inside
