Solved CAPTCHA incorrectly shown?
9 years 5 months ago #1 by MatthijsWink
Hi have a question. In my forum, I have set CAPTCHA Challenge for users : 0
This should means when a registered user answers to a post, no captcha is used.
However, for a specific user Captcha is shown (but for other users not).
What triggers this ?
thanks for any help!
9 years 5 months ago #2 by MatthijsWink
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 20M
Joomla default template details : yoo_moreno | author: YOOtheme | version: 1.0.6 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: CommunityBuilder 1.9.1
Plugins: None
Modules: Kunena Latest 3.0.1
9 years 5 months ago #3 by 810
Replied by 810 on topic CAPTCHA incorrectly shown?
that's strange, try to sync users, I don't think it will work, but we can try it.
backend - kunena - tools -sync users - select all users - click on sync
9 years 5 months ago #4 by sozzled
Replied by sozzled on topic CAPTCHA incorrectly shown?
You have this configuration setting:
Configuration » Security » Security Settings » Allow Guests to Post/Write = Yes
I also see that you have the settings
Configuration » Security » Security Settings » CAPTCHA Challenge for Guests = No
Configuration » Security » Security Settings » CAPTCHA Challenge for Users = 0
I agree with 810: I also think this is strange. Theoretically there should be no CAPTCHA challenge for guests or registered users. Perhaps using the Synchronising users feature will work.
9 years 5 months ago #5 by MatthijsWink
Hi thanks for your replies.
I did the Sync -> but no results!
I still have a specific user that gets Catchpa and other users that don't ...
any other suggestions ?
thanks!
9 years 5 months ago #6 by MatthijsWink
just noticed that for the user that gets the Catchpa, I also need to conform posts.
While for regular registered users, this is not necessary. So looks like there is something special with this user ...
9 years 5 months ago #7 by 810
Look at the joomla user manager, and find the user. Then check if the user is assigned to Registered group.
9 years 5 months ago #8 by MatthijsWink
He is part of Registered group ...
9 years 5 months ago #9 by rich
Replied by rich on topic CAPTCHA incorrectly shown?
Open this user (Edit). Afterwards save without change.
The following user(s) said Thank You: MatthijsWink
9 years 5 months ago #10 by MatthijsWink
Hi Rich: this worked!!
But not sure what caused this / how can I check if other users could have same issue ??
thanks!
Time to create page: 0.392 seconds
