- Thank you received: 3
Kunena 6.2.6 released
Solved Poll Answer - Length
- perryworld
- Topic Author
- Senior Member
9 years 9 months ago #1
by perryworld
Poll Answer - Length was created by perryworld
We are using Kunena 3.0 and have just tried to add a poll but are having a problem as the length of the answers are restricted to 25 characters.
Is it possible to increase the length of the answers and if there is what would we need to do.
Cheers
Rich
Cheers
Rich
- perryworld
- Topic Author
- Senior Member
9 years 9 months ago #2
by perryworld
Replied by perryworld on topic Poll Answer - Length
Hi All,
Any one got any ideas how we can achieve this
9 years 9 months ago #3
by xillibit
Replied by xillibit on topic Poll Answer - Length
You can look in the template and increase the value of length for input fields for options of poll
- perryworld
- Topic Author
- Senior Member
9 years 9 months ago #4
by perryworld
Thanks for the reply, Do you know which file this will be in - is it in the administration folder or in the component.
We are on Kunena 3.0.5 and are using the blue eagle template.
Rich
Rich
9 years 9 months ago #5
by xillibit
Open the file /media/kunena/js/poll.js and change at line 22 the maxlength by something more higher
The following user(s) said Thank You: perryworld
- perryworld
- Topic Author
- Senior Member
9 years 9 months ago #6
by perryworld
Thanks xillibit
That solved the problem
Cheers
Rich
Cheers
Rich
- perryworld
- Topic Author
- Senior Member
9 years 7 months ago #7
by perryworld
Just as a follow up to this question is it possible to increase the size of the poll TITLE as it seems to be restricted to 100 characters
Thanks for your help
Rich
Rich
Time to create page: 0.411 seconds
