Question White Screen loading posts - insufficient memory
9 years 7 months ago #1 by adrikai
Greetings!
The kunena forum all works fine except one thing, when I want to load any post browser goes blank (I've tried multiple browsers) deleted cache, history, cookies, and goes blank.
I also unistall and installed everything from 0 and I deleted all the files.
  PHP 5.4.16
  MySQLi 5.1.73
Could you please help me
9 years 7 months ago #2 by xillibit
Can-you put here please your Kunena configuration report settings ?
In Joomla! configuration panel, in tab server set error report to maximum and instead of white page you should have an error message.
The following user(s) said Thank You: adrikai
9 years 7 months ago #3 by adrikai
hi sorry for the time,
Report :
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 16M | Max file upload: 8M
Joomla default template details : J51_Nocturne | author: Joomla51 | version: 1.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: None
9 years 7 months ago #4 by adrikai
9 years 6 months ago #5 by adrikai
??? any can help me
9 years 6 months ago #6 by xillibit
xillibit wrote: Hello,
Do-you have tried that to get an error message ? You can look too in your apache error log or server log to get the error message.
9 years 6 months ago #7 by rich
hm.. I can't see a blank page. For me it works your forum. Please empty your browser cache and try again.
9 years 6 months ago #8 by adrikai
The error is not always, sometimes, for example now you can not read the post, but if you see the forum. I can not look my apache server for my hosting. The funny thing is that sometimes happens
9 years 6 months ago #9 by adrikai
ok .. this is the error .
500 Internal Server Error
Fatal Error was detected!
Fatal Error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 96 bytes) in libraries/joomla/language/language.php on line 807
The error was detected in the Libraries.
Go back
9 years 6 months ago #10 by rich
Your system requirements are too low. Kunena 3.0 requires minimum memory_limit 32M. You have only 16M.
www.kunena.org/docs/Technical_Requirements#cite_ref-4
If even a few extensions are installed, then at some point there is this error. Ask your provider whether he increases the memory limit.
Time to create page: 0.947 seconds
