Welcome, Guest
Username Password: Remember me
Keyword
  • Page:
  • 1
TOPIC: Problem with log in CB
Problem with log in CB 2 years ago #1
I close register in Global config it's show 404 massage error
I use CB log in...and register
when i register and i 've confirm link in email
then i go to log in in CB and Webbaord...It's show massage like i'm not confirm link in my email yet.....
and also said admin not been approved ...when i checked...i all approved
Please help me again
my site is www.siliconeclub.com
sorry for poor language
thanks a lot
  • jeepono
  • OFFLINE
  • Fresh Boarder
The topic has been locked.
Re:Problem with log in CB 2 years ago #2
I think you are saying that you are having a problem with the Community Builder login module. Is that right? You will find better information about Community Builder if you visit their discussion forum at Joomlapolis.
  • sozzled
  • OFFLINE
  • Kunena Moderator
  • I'm just a user, mate
If you benefit from our help you can show your appreciation by using the Thank You feature.
If you think I'm wrong then say "I think you're wrong." If you say "you're wrong", how do you know?
Re:Problem with log in CB 2 years ago #3
Well I got the same problem for a while.... really annoying
Plus I'm pretty much n00b with php and stuff, however as an Enginner, I started a surch around the web and I found almost all good hints here.
Thank you guys...
However, after try almost everything I found here I still couldn't solve the "thing".
So I checked all again and I found a little plugin in the CB.
This plugin called Forum Integration (cb.simpleboardtab) and it was set to Registered, so I changed it to Public... problem solved, no more error 404 when users click Register in the Kunena Forum:
Some aditional info:
► Joomla 1.5.14
Global Configs ► Allow User Registration ► NO
Global Configs ► Cache Settings ► NO
Tools ► Clean Cache ► OK
► Kunena 1.5.6
Avatar Integration ► COMMUNITY BUILDER
Profile Settings ► COMMUNITY BUILDER
Sync ► OK
► CB 1.2.1
Registration ► Allow User Registration ► YES, INDEPENDENTLY OF GLOBAL SITE SETTING
Integration ► AUTOMATIC
Sync ► OK
Table Structures and etc ► OK
Plugin Management ► Forum Integration ► PUBLISHED/PUBLIC/SET TO IDENTIFY FORUM AUTOMATIC.
I hope this could help someone.
In advance thanks for your help, because I could handle this after found all infos in this forum ! Good Job !
Ps.: you can check it working at www.l2-adrenaline.com
  • miraz
  • OFFLINE
  • Fresh Boarder
Re:Problem with log in CB 2 years ago #4
Or just upgrade Kunena to the latest version.. It will fix this too, and you do not have to set profiles link to Public.
  • Matias
  • OFFLINE
  • Kunena Developer
  • Kunena!
No, I'm not reading my private messages. Please use forum to get support and email for private matters.
Reviews on the Joomla Extension Directory are always appreciated.
  • Page:
  • 1
Time to create page: 0.41 seconds
