Question Search Plugin does not work
13 years 4 months ago #11 by mibert
Hi there,
finally I found the second problem with the search plugin.
The first one is the naming issue, as Louis suggested earlier.
The reason, why the plugin only found topics, which was written before the forum update was, that the search plugin was looking up the MySQL table #__fb_messages and #__fb_messages_text.
However, the migration script, converting Kunena 1.5 into Kunena 1.6 is creating new tables, which are called #__kunena_messages and #__kunena_messages_text.
By changing this table names in the plugin script, its now working fine.
I would recommend to update the search plugin in the download area.
I am still wondering, why nobody else faced the same issue. It should apply to everybody, who upgraded from Kunena 1.5 to 1.6.
Anyway, thanks for trying to help and have a nice weekend
Best regards
Michael
13 years 4 months ago #12 by xillibit
There are two search plugins : one plugin has been designed by a third party personn which is not in kunena team and had released a version for k1.5.x
one other plugin has been made by kunena team and is available here :http://joomlacode.org/gf/project/kunena/frs/
13 years 4 months ago #13 by mibert
Hi xillibit,
the plugin, which has the two above bugs is the one, which I downloaded from joomlacode.org/gf/project/kunena/frs/
plg_kunenasearch_v1.6.0-RC2_b94_2010-08-31.zip
Its not the third party plugin.
Best regards
Michael
13 years 4 months ago - 13 years 4 months ago #14 by yaksushi
I tried updating the kunenasearch.php and changed
$query = "SELECT m.id, m.subject AS title, m.catid, m.thread, m.name, m.time AS created, t.mesid, t.message AS text, m.ordering, mm.hits, c.name AS section, 1 AS browsernav FROM #__fb_messages_text AS t INNER JOIN #__fb_messages AS m ON m.id=t.mesid INNER JOIN #__fb_messages AS mm ON mm.id=m.thread INNER JOIN #__fb_categories AS c ON m.catid = c.id WHERE {$where} AND m.moved=0 AND m.hold=0 AND mm.hold=0 AND mm.catid IN ({$ksession->allowed}) GROUP BY m.thread ORDER BY {$order}";
to
$query = "SELECT m.id, m.subject AS title, m.catid, m.thread, m.name, m.time AS created, t.mesid, t.message AS text, m.ordering, mm.hits, c.name AS section, 1 AS browsernav FROM #__kunena_messages_text AS t INNER JOIN #__kunena_messages AS m ON m.id=t.mesid INNER JOIN #__kunena_messages AS mm ON mm.id=m.thread INNER JOIN #__kunena_categories AS c ON m.catid = c.id WHERE {$where} AND m.moved=0 AND m.hold=0 AND mm.hold=0 AND mm.catid IN ({$ksession->allowed}) GROUP BY m.thread ORDER BY {$order}";
but it didn't work...
Last edit: 13 years 4 months ago by yaksushi.
13 years 4 months ago #15 by mibert
You also have to rename kunenasearch.php to kunena.php
Then it should work.
The following user(s) said Thank You: yaksushi
13 years 4 months ago #16 by yaksushi
mibert wrote: You also have to rename kunenasearch.php to kunena.php
Yes that worked!! Do I need to rename kunenasearch.xml as well?
13 years 4 months ago #17 by mibert
I think its not needed.
Best regards and merry christmas
Michael
Time to create page: 0.543 seconds
