Welcome, Guest
Username: Password: Remember me
Keyword
  • Page:
  • 1
TOPIC: First Article on Forum in "spoiler"
First Article on Forum in "spoiler" 2 months 3 weeks ago #1
Hi all,
is possible to put between the tags "spoiler" the first message generated automatically?
Rather than
[article]x[/article]
write automatically
[spoiler][article]x[/article][/spoiler]
If possible, how?
  • Dreeg
  • Dreeg's Avatar
  • OFFLINE
  • Fresh Boarder
The administrator has disabled public write access.
Re: First Article on Forum in "spoiler" 2 months 3 weeks ago #2
I tested this and I know that you can combine the spoiler tag with the article tag and this combination works. You can edit the BBcode of the automatically-generated forum topic and change the first message so that it uses a spoiler tag, if that is what you want to do.
I am sure it is possible to change the way that the Kunena Discuss plugin works so that, in your case, all your articles will automatically generate spoilers + article tags. For any amount of money, your time or your own PHP coding skills, you can change Kunena to do virtually anything you want to do. The Kunena Discuss plugin is free and its functionality is limited to what you are able to download from this site. Depending on your own ability to change the software, or a budget to employ someone else to make these changes for you, you can change this free software.
The Kunena Discuss plugin does not automatically do what you want it to do. However, Kunena Discuss plugin is open source software and you can change it. I do not know, specifically, where or what you would need to change. Perhaps someone else who is feeling generous might like to give you the information.
  • sozzled
  • sozzled's Avatar
  • NOW ONLINE
  • Kunena Moderator
  • I'm just a user, mate
  • Thank you received 1902
If you benefit from our help you can show your appreciation by using the Thank You feature.
Dicat putat mei peccatorem, sed si dixerit, "peccator es!", hunc scit?
Last Edit: 2 months 3 weeks ago by sozzled.
Re: First Article on Forum in "spoiler" 2 months 3 weeks ago #3
Thanks sozzled, you're always available, clear and concise manner and kind in every category of the forum. Thanks again!
Today I took a look at the code, I will try better tomorrow.
Thanks for the link suggested, I will see.
  • Dreeg
  • Dreeg's Avatar
  • OFFLINE
  • Fresh Boarder
  • Page:
  • 1
Time to create page: 0.331 seconds
