Question [Merged topic] Menu tabs display vertically
13 years 6 months ago - 13 years 4 months ago #1 by saddoris
I've just installed 1.6 final over an existing version, and while the install went beautifully, the menu tabs are displaying in a vertical list, rather than inline. Any ideas??
Last edit: 13 years 4 months ago by sozzled. Reason: Merged topic: Changed subject to improve search relevance
13 years 6 months ago #2 by fxstein
1.) Can you please provide your config report
2.) Have you cleared your browsers cache?
13 years 6 months ago #3 by Matias
We are using Main Menu module to show our own menu. Your template may have CSS rule for it:
div.moduletable ul.menu
Please use FireBug, Opera inspect or similar tool to find out which CSS rules apply to those elements.
13 years 6 months ago - 13 years 6 months ago #4 by saddoris
I'll check the CSS for Main Menu. One thing, if I change the Kunena Menu type to Legacy - Horizontal they change. They still don't display correctly, but they are at least horizontal. Have cleared cache. Do I paste in the report or attach as .txt?
Here are the only references to "div.moduletable ul" in the main template CSS:
/* mis */
div.moduletable ul {
margin: 0;
padding: 0;
list-style-type:none;
list-style: none;
div.moduletable ul li {
margin: 0;
padding-left: 0px;
list-style: none;
Last edit: 13 years 6 months ago by saddoris.
13 years 6 months ago #5 by Matias
There may be other rules as well, which are affecting to the menu. So FireBug or similar tool would be handy.
Or you could give us URL to your forum so that someone could take a look on it.
13 years 6 months ago #6 by saddoris
Ooops...Duh on my part forgetting the URL. Sorry about that
fadedandblurred.com/forum/
Thanks guys.
13 years 6 months ago #7 by saddoris
I just added a Module Class Suffix of "_kun" to the Kunena Menu, then added the same suffix in the kunena.forum.css
#Kunena #ktab div.moduletable_kun ul.menu li {
display: inline;
float: left;
margin: 2px 2px 0 0!important;
padding: 0;
border: 0;
Is that at acceptable solution, or merely a clumsy hack?
Thanks again.
13 years 6 months ago #8 by Matias
It works.
I cannot see the menu at all..?
13 years 6 months ago #9 by saddoris
Should be available now. Also, and this is weird. Clicking the forum button takes you to the forum, but gets this error:
Kunena Notice: No menu item assigned. Redirected to /forum (Itemid=139).
Refreshing the page or simply pressing the Forum button again makes it go away.
13 years 6 months ago #10 by Matias
Time to create page: 0.554 seconds
