- Thank you received: 10
Kunena 6.2.6 released
Question Kunena RTL CSS for K1.6 Final
Live website with new css files:
www.cyberg.ir/index.php?option=com_kunen...t&catid=0&Itemid=119
sozzled wrote: Thanks, Masoud. Would you like to add this to the Kunena Extensions Directory ? I think it would be better placed there and it would be easier for other users to find it, too.
I can find some problem in css files after fixing them, I'll ask you for that.
I will try it
Thank you very much
I think the RTL should be part of the component
What happens when we working with joomfish?
When I work with design templates I'm working with this code
We need to see how developers can add this to the component<?php if($this->direction == 'rtl') : ?><link rel="stylesheet" href="templates/<?php echo $this->template ?>/css/template_rtl.css" type="text/css" /><?php endif; ?>
Then you must create another CSS file in the library
I want to know what you think and what the developer's opinion
Sorry if my English is not clear
kobi
#kadmin {
direction:ltr;
text-align:left;
../administrator/components/com_kunena/media/css/admin.css
I guess the problem will solve.
