- Thank you received: 1
Kunena 6.2.6 released
13 years 8 months ago - 13 years 8 months ago #2
Replied by sozzled on topic Re: K 1.6 bbCode and smileys not working
I'm only making a guess here. Although K 1.6 is very different to K 1.5 and (as I understand things) the Javascript-written client-side script that handles BBcode has been radically changed from K 1.5, it's still possible for another client-side script to be running on your PC that interferes with the BBcode behaviour. What I'm trying to say is that, we should have eliminated most of these "my BBCode and smileys aren't working" problems with K 1.6, but we may not have eliminated them all.
In the past, the standard approach to these issues is to look for conflicting Joomla extensions (components, modules, plugins, templates, languages). I would suggest you do the same.
If you search anywhere in these forums for "BBcode not working" or "boardcode not working" or "conflicting plugins" you will find hundreds of examples that may possibly be of help to you.
Most importantly and before I forget: if you find the answer would you please share it with us? Thanks.
Last edit: 13 years 8 months ago by sozzled.
The topic has been locked.
13 years 8 months ago #3
by etusha
Replied by etusha on topic Re: K 1.6 bbCode and smileys not working
ARE u using JS compress ?
13 years 8 months ago #4
by Cerberus
Replied by Cerberus on topic Re: K 1.6 bbCode and smileys not working
ok few questions:
joomla version:
Kunena Build Number:
Templates used: ( kunena and joomla )
Browser Used:
Any custom modules, plugins or components:
joomla version:
Browser Used:
- rinuccio sp
- Premium Member
- Thank you received: 4
13 years 8 months ago #5
by rinuccio sp
Replied by rinuccio sp on topic Re: K 1.6 bbCode and smileys not working
The following user(s) said Thank You: roland76
13 years 8 months ago #6
by Cerberus
That plugin is already part of the public beta..
rinuccio sp wrote: Use this plugin
www.kunena.com/forum/156-kunena-16-test-...opdown-missing#52040
13 years 8 months ago #7
by tromp
Replied by tromp on topic Re: K 1.6 bbCode and smileys not working
I have simply solved the problem System - Mootools Upgrade (1.2.4) was disabled. Problem was solved after enabling this plugin.
Anyway, Thanks for the support.
Tromp
Tromp
The following user(s) said Thank You: Helixir
- Luís Gonçalves
13 years 8 months ago #8
by Luís Gonçalves
Replied by Luís Gonçalves on topic Re: K 1.6 bbCode and smileys not working
I'm having the same problem, in many test websites. I have the plugin activated.
- rinuccio sp
- Premium Member
13 years 8 months ago #9
by rinuccio sp
13 years 8 months ago - 13 years 8 months ago #10
G'day, Luis, and welcome to Kunena. Thank you for your report about this issue.
Would you please provide us with the configuration settings report, from any one of your test sites where you state:
Time to create page: 0.502 seconds
