Question Reverse Post Order Solution
1) Create a trigger in mysql wich every time that a row is inserted on the user table, the ordering field is set to 0 instead of 1.
2) Find the file and code where the INSERT of the user is done and modify it by replacing ordering = 1 to ordering = 0.
Anyone can help with this? I use Community Builder and I don't know how it does Kunena to get every new registered user...
EDIT: is one OR another, not both
do you want change the order in the userlist ? or do you want change the order of posts ?
The only way to change this is to modified the file components/com_kunena/template/dafault_ex/view.php at line 168 replace:
by this
It works perfectly! Thank you, xillibit! You found the solution that many Kunena users where looking for!
In /administrator/components/com_kunena/libraries/tables/kunenauser.php find:
var $ordering = null;
and fix in:
var $ordering = 1;
Visitors and new users will see the reverse order, and have already registered you must change the option in the settings in backend.
(i'm don't speak english - google translator )
Pozdrawiam,
Harykopar
