Welcome, Guest
Username Password: Remember me
Keyword
TOPIC: Trying to install Kunena - having problems with directory permissions
Trying to install Kunena - having problems with directory permissions 2 years ago #1
I am trying to install Kunena In too my Joomla Site and when I do I get this erro when I have debug on
-1 - An error has occurred.
Unable to create target folder
Call stack
# Function Location
1 JAdministrator->dispatch() /user/homepages/virtual/eacentral/eabytes/administrator/index.php:67
2 JComponentHelper->renderComponent() /user/homepages/virtual/eacentral/eabytes/administrator/includes/application.php:136
3 require_once() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/application/component/helper.php:162
4 JController->execute() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_installer/admin.installer.php:44
5 InstallerController->doInstall() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/application/component/controller.php:236
6 InstallerModelInstall->install() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_installer/controller.php:71
7 JInstaller->install() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_installer/models/install.php:86
8 JInstallerComponent->install() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/installer/installer.php:332
9 com_install() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/installer/adapters/component.php:293
10 JFolder::copy() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_kunena/install/kunena.install.php:149
11 JError::raiseError() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/filesystem/folder.php:64
12 JError::raise() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/error/error.php:171
13 JException->__construct() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/error/error.php:136
When Debug in joomla is off I only get the
Now heres the kicker when I give all folders full write access it will install just fine witch makes me think that it is a permssion prob but I really don't want to have my site open to everyone that will leave the server open to hackeking so what do I do to fix this?
thanks
tbarlow
  • tbarlow
  • OFFLINE
  • Fresh Boarder
Last Edit: 1 year, 11 months ago by sozzled. Reason: Changed subject to imrpove search relevance
The topic has been locked.
Re: Securing Kunena 2 years ago #2
Please read Securing Kunena in the Wiki.
  • sozzled
  • OFFLINE
  • Kunena Moderator
  • I'm just a user, mate
If you benefit from our help you can show your appreciation by using the Thank You feature.
If you think I'm wrong then say "I think you're wrong." If you say "you're wrong", how do you know?
Last Edit: 2 years ago by sozzled.
Re: Securing Kunena 2 years ago #3
ok well I read that and its still doing the same thing?
  • tbarlow
  • OFFLINE
  • Fresh Boarder
Re:Securing Kunena 2 years ago #4
This issue isn't related to security...
I have modified a bit Kunena 1.5.9, i hope that will solve your issue :
xillibit.perso.sfr.fr/ftp/com_kunena_v1....-21-with_fix.tar.bz2
Tell me if this has worked after an new installation
  • xillibit
  • NOW ONLINE
  • Kunena Developer
  • Kunena always better
Become a Kunena fan
Last Edit: 2 years ago by xillibit.
Re:Securing Kunena 1 year, 11 months ago #5
This didn't work for me personally. I was getting an error on the actual .tar file when trying to extract it.
Uploading to Joomla, I got another error saying "Unable to write entry" and then this...
Warning: file_put_contents(/tmp/install_4b8c1cc774255/:K�]�]u��nZ���Ρ���J�����=��d�����w���$��?����K ݄�����hh�t��]d�4�~�cRO(妍) [function.file-put-contents]: failed to open stream: Is a directory in /****/*****/public_html/libraries/joomla/filesystem/file.php on line 298
Completely out of my depth! While I think the Kunena forum is fantastic, is there not a way of making the installation easier? I don't have these problems with anything else.
Last Edit: 1 year, 11 months ago by RedElectro. Reason: to include actual error code.
Re:Securing Kunena 1 year, 11 months ago #6
RedElectro: I sympathise with your frustration and, while the questions I am about to ask you may seem pointless, I would like to help obtain the best advice for you.
I understand that you are trying to install Kunena when you encounter these problems.
What are the directory and file permissions on your website?
What version of Kunena are you trying to install? Which installation kit are you using?
What version of Joomla are you running?
What version of PHP are you using?
What kind of webserver is involved and what kind of database system is being used?
  • sozzled
  • OFFLINE
  • Kunena Moderator
Re:Securing Kunena 1 year, 11 months ago #7
Hi Sozzled thanks for the reply...
I have gone through each relevant directory/sub directory and set the Perms to 777
I am trying to install Kunena 1.5.9 and I currently have 1.5.6 installed.
I am running Joomla 1.5.15
Apache version 2.2.14
PHP version 5.2.11
MySQL version 5.0.89-community
Hope this helps?
Thanks in advance
Red.
Last Edit: 1 year, 11 months ago by RedElectro. Reason: to make post more accurate.
Re:Trying to install Kunena - having problems with directory permissions 1 year, 11 months ago #8
Thank you very much for your reply. You clearly meet and exceed the minimum technical requirements for Kunena. It's a bit of a puzzlement why your installation fails. The evidence seems to suggest that it's a directory permissions problem.
I noticed, from an earlier message, you said something about a .TAR file. Are you trying to install Kunena 1.5.9 from a .TAR file? Have you tried to use the .ZIP installation kit instead (this is a long-shot, I know, but I've heard other people have had problems installing with a .TAR archive)? Let's at least eliminate this possibility.
  • sozzled
  • OFFLINE
  • Kunena Moderator
Re:Trying to install Kunena - having problems with directory permissions 1 year, 11 months ago #9
I originally tried the zip file and had issues. It was Xillibit's post above that prompted me to try the tar install.
I have set the permissions in the components/com_kunena and administrator/com_kunena to 777 almost every file and every folder and I'm still not having any success.
It's got me completely puzzled.
Re:Trying to install Kunena - having problems with directory permissions 1 year, 11 months ago #10
Yes, but you still haven't answered my question. Now that you have changed directory and file permissions, have you attempted to use the .ZIP file installation and, if so, what are the specific "issues" that you encounter?
  • sozzled
  • OFFLINE
  • Kunena Moderator
Time to create page: 0.44 seconds
