Welcome, Guest
Username Password: Remember me
Keyword
  • Page:
  • 1
TOPIC: Joomlaboard to kunena plz help
Joomlaboard to kunena plz help 2 years ago #1
Hi, I have an ancient relic on my running site - joomlaboard. And it has become a problem when decision of migration to joomla 1.5 was made.
I have searched this forum and found this topic:
www.kunena.com/forum/101-solved-or-prior...ached-images-missing
Matias said that there is some script for migration from jb to kunena.
Matias wrote:
BTW: Kunena has also migration possibility from JoomlaBoard, but it seems to be slightly broken. I can try to fix it if someone gives me a database dump from sb_* tables.
Is it still broken? Is there a way to fix it and get?
  • Demnus
  • OFFLINE
  • Fresh Boarder
The topic has been locked.
Re:Joomlaboard to kunena plz help 2 years ago #2
I think there are nothing news about this. But you can send a MP to matias with explenations and give him a dump of your tables begining by sb_*.
  • xillibit
  • NOW ONLINE
  • Kunena Developer
  • Kunena always better
Become a Kunena fan
Re:Joomlaboard to kunena plz help 2 years ago #3
Did send a PM to Matias, but there's no response.
Guess have to try through FB.
*sigh* It's going to be painful...
  • Demnus
  • OFFLINE
  • Fresh Boarder
Re:Joomlaboard to kunena plz help 2 years ago #4
It would be a great benefit to find a smooth way of transitioning from Joomlaboard to Kunena! I can think of one or two big websites that would gain from this ...
I'm sorry you haven't received an answer. As you know, the developers are working around the clock (literally) on the next version of Kunena. In the meantime I can only suggest you work through the other ideas that have been offered in the past, for example Migration from JoomlaBoard to Kunena. I agree, it's not easy and you may have to do a lot of fine-tuning, but if you take things carefully, using a temporary staging area, you should be able to get good results.
Worst-case scenario, leave your old Joomlaboard site as a stand-alone archive, lock it up (prevent new registrations and postings) and build a new website that refers back to the archived discussions. OK?
  • sozzled
  • OFFLINE
  • Kunena Moderator
  • I'm just a user, mate
If you benefit from our help you can show your appreciation by using the Thank You feature.
If you think I'm wrong then say "I think you're wrong." If you say "you're wrong", how do you know?
Re:Joomlaboard to kunena plz help 2 years ago #5
I was away because of personal loss.
Kunena 2.0 will most likely have migration from JoomlaBoard -- it's really easy to do with the new installer (just one line into array). In the meanwhile I suggest looking at the thread sozzled suggested. It's actually what FireBoard does when it migrates from JB.
Or just try to find old version of FB and use it.
  • Matias
  • OFFLINE
  • Kunena Developer
  • Kunena!
No, I'm not reading my private messages. Please use forum to get support and email for private matters.
Reviews on the Joomla Extension Directory are always appreciated.
  • Page:
  • 1
Time to create page: 0.37 seconds
